$13.00
This 200g (7 oz) stainless steel ballast weight is compact and has a screw hole for easy mounting.
Available on backorder
U.S. customers will be charged a tariff surcharge of $1.56 for this product. Learn more
SKU: BR-101039 Category:
HS Code: 7218.91.00
Country of Origin: China
This 200g (7 oz, 0.43 lb) stainless steel ballast weight is designed to be low-drag and easy to mount on your ROV or AUV. The countersunk mounting hole is perfect for a #8 or 4mm screw diameter.
  • 1 x 200g Stainless Steel 316 Ballast Weight
  • 1 x 8-18 Thread, 5/8″ Long, Thread-Forming Screw
Physical
Weight in Air191 g6.7 oz
Weight in Water165 g5.8 oz
MaterialPassivated Stainless Steel (AISI316)
 Drawing
BALLAST-200G-R2 (.zip)
14 July 2023
  • BALLAST-200G-R2-RP SKU changed to BR-101039
2 January 2019
  • R1 - Initial Release
